DLM
22 REPLIES 22
Acebull
Hi, I'm not sure if im on the best profile or what but I possibly would like a request to reset the DLM and optimize the connection, thanks.
If you check your router stats and post them here that will give us an idea.
Acebull
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)15.08.0
Attenuation (dB)30.518.5
Output Power (dBm)18.811.9
Attainable Rate (Kbps)81601312
Rate (Kbps)78721024
K (number of bytes in DMT frame)24733
R (number of check bytes in RS code word)816
S (RS code word size in DMT frame)1.001.00
D (interleaver depth)328
Delay (msec)8.008.00
INP (DMT symbol)0.500.33
Super Frames160172794155598606
Super Frame Errors86033
RS Words1779919686444987206
RS Correctable Errors715667
RS Uncorrectable Errors50
HEC Errors1051890
OCD Errors00
LCD Errors00
Total Cells39665276480
Data Cells5083863720
Bit Errors2110
Total ES45850
Total SES130
Total UAS305295
Acebull
I am using the Billion 7800 router, I also have a Archer VR900 around my place somewhere but cant find it, thought that would probably help a little bit too
Acebull
Actually it says 8800NL
OK, thanks for that. The SNR does seem set very high, can you give us a bit more information about your internal setup, especially whether you have more than one phone socket and if your router is connected at the master socket. Also, are you aware of any issues with your landline service such as noise on the line?
Subject to that the support team here will gladly look into this for you, make sure that your personal details including TalkTalk landline number are complete on your community profile here so that they can link your forum identity with your account and then wait for them to respond.
Acebull
I tried adjusting the SNR manually with one of the settings built into the router to I could influence the profile change myself but it doesnt seem to work, well I have a 0.5m adsl wire thats going from the router to the small d-link microfilter straight into the test socket and like a 1/2m ethernet cable then going into my computer, I dont use the landline unless I really need to it's usually turned off, my router is actually connected to an extension socket from the master if thats what you mean but I dont think that would stop a better profile change from where it is now? I prefer G.dmt than ADSL2+ because it seems just better stability
Acebull
powered* from the extension socket with multiple other ones plugged in, I assume you meant the faceplate, my bad
OK, the problem is if you have a router where you can tweak the SNR settings yourself is that it will not necessarily reveal any underlying issues. Do you have a TalkTalk router which you can connect temporarily whilst any checks take place?
Acebull
I havent tried to do that for a while and just left it the way it should be for a couple of months but when I did try it like I did when I was with sky it didn't work so was no benefit to that option everything is fine I guess would just like to try my luck resetting the DLM and optimising it and see what happens
Hi Acebull,
I've optimised the connection now, please let us know how the speed compares over the next 24hrs.
Acebull
I think I might be on the best profile or just locked right now because my attainable rate is considerably higher, if only SNR could be tweaked or something but it can't
Acebull
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
SNR Margin (dB)14.89.0
Output Power (dBm)19.011.8
Attainable Rate (Kbps)81601328
Rate (Kbps)78721024
Super Frames184764873180190685
Super Frame Errors113392074
RS Words508248082127063202
RS Correctable Errors78168
RS Uncorrectable Errors110
HEC Errors1068052065
OCD Errors00
LCD Errors00
Total Cells23590332850
Data Cells880029880
Bit Errors5420
Total ES46560
Total SES760
Total UAS575502
Hi Acebull,
Current sync speed is 7.8Mbps, Your ADSL mode is G.DMT which will limit your speed. If you set the ADSL mode in your router to auto this should improve your speed
Acebull
I am on ADSL2+ instead of G.DMT but im stuck on like 12mb when my attainable rate is nearly 16mb, why is it stuck and can anything be done to force a change? maybe reset everything to how it was and reoptimize things, my setup is perfect, thanks.
Can you post your current router stats as you did earlier? You certainly seem to be getting near to the rate which your attenuation suggests, the "attainable" rate will always be artificially high as this does not take into account any overheads.
Acebull
ModeADSL_2plus
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
SNR Margin (dB)6.913.2
Attenuation (dB)33.517.8
Output Power (dBm)0.012.9
Attainable Rate (Kbps)159681220
Rate (Kbps)122871019
MSGc (# of bytes in overhead channel message)7912
B (# of bytes in Mux Data Frame)96127
M (# of Mux Data Frames in FEC Data Frame)11
T (Mux Data Frames over sync bytes)31
R (# of check bytes in FEC Data Frame)1610
S (ratio of FEC over PMD Data Frame length)0.25173.9855
L (# of bits in PMD Data Frame)3591277
D (interleaver depth)968
Delay (msec)68
INP (DMT symbol)1.501.00
Super Frames28531682533608
Super Frame Errors70
RS Words72755753145926373
RS Correctable Errors7437776
RS Uncorrectable Errors340
HEC Errors180
OCD Errors00
LCD Errors00
Total Cells1326988115109725427
Data Cells256054181471284
Bit Errors16540
Total ES70
Total SES00
Total UAS7070
I had the same stats as when I was with sky, unless it's connected to a different exchange Idk but DLM would shoot me right up to 20mb+ if I had left DLM for like a week or 2 and there was consistent profile changes, I used to get a few profile changes when I joined talktalk but I'm not sure if something has gone wrong, it would be cool to reset it all and let it do the same thing or something
OK, your SNR margin is still a wee bit above the target of 6dB. Forgive me if you have been asked, or done this before, but can you try connecting at the test socket and see if that improves things? Your connection is definitely on an upward track though, so let's see what the OCE have to say when they check from their end again.
Hi Acebull,
Thanks for the update. I can see that DLM has increased the sync speed. How have you found the performance of the connection?
Acebull
DLM hasn't taken affect on my profile for months, if it's disconnecting a decent bit that was me trying to change a few things to benefit my profile but it seems that I'm locked/banded in this profile and nothing can be done, speed goes up a maximum of about 200/300 kbs if I switch back to the test socket
