DSL-3780 firmware old version (1.19t)?
5 REPLIES 5
I am seeing warning about my parents router (the D-Link DSL-3780) which is apparently on a firmware version which is at risk of attack (1.19t)?
I have tried to update this but it seems this router is not supported anymore on the D-Link website as it doesn't have the 3780 in their list of products, and i can't find it anywhere else.
Does anyone know where the most recent firmware is?
Mike
V1.19 is the latest firmware & it fixes all known security vulnerabilities. However, if you know of any specific vulnerabilities, let me know & I'll get the OCEs involved for you.
Hi Mike1233
If you add the telephone number (for your parents) in the Private Notes section of your Community Profile then I can check the firmware version for you.
Hi @OCE_Debbie,
Thank you for checking, the landline number for my folks is there in my profile.
Mike
Chat Champion
I had the same problem with AVAST SECURITY constantly telling me the router was vulnerable despite being told otherwise from talk talk.Anyhow replacement router cured these warnings,so maybe with a bit of luck a new router might be the answer `might be`good luck.
Hi Mike
Your folks router is running the latest firmware.
