DSL-3782 Router Dropping Connection
pbar100
Enlightened One
Message 15 of 15
Hi, I have a DSL-3782 TalkTalk router which is dropping connection daily. I have only used this router for a few days, prior to this I used my own Netgear one which was perfect.
Is this a known fault with these or is there a firmware upgrade available perhaps.
Thank you.
14 REPLIES 14
Message 1 of 15
Hi pbar100
I will take a look at your other thread now.
Message 2 of 15
As promised, I said I'd report back and certainly since the 'upgrade' to fibre the connection has been more constant. Still disconnects but it does re-connect itself. However, I have another related problem which I'll start a new thread about.
Message 3 of 15
Hi pbar100
Ok no problem 🙂
Message 4 of 15
Thanks very much Debbie, for your quick reply and very helpful suggestion.
I don't wish to trouble you unecessarily, so with the TalkTalk fibre upgrade rollout reaching me tomorrow, it makes sense for me to wait until that's complete, and see if the issue remains after that.
As it may solve itself, who knows. Either way, I shall post back and let you know.
Thank you again 🙂
Message 5 of 15
Hi pbar100
Apologies for this.
Would you like me to send a different make and model of router for testing?
Message 6 of 15
Unfortunately, after what looked to be a promising fix, I've been suffering with frequent dropped connections, at least once or twice a day at times.
My own previous Netgear router was fine. The TalkTalk routers do seem quite flaky, but they are given away free after all. I would still expect it to work though.
It is important for me to have a reliable connection, as when away from home I view CCTV cameras, so a dropped connection obviously stops this.
When it happens, all router lights usually remain green as normal, but on occasion either the broadband or internet lights have shown red. I do believe it is just the unreliability of these routers.
I am about to have a non requested upgrade to fibre however, so will see if it is still the same then.
Message 7 of 15
Thanks for the update and I'm glad to hear this 🙂
Message 8 of 15
@Chris-TalkTalk  Thanks Chris, I appreciate it.
All good so far, no drop outs since 'always on' was enabled. Here's hoping!
Message 9 of 15
OK pbar100, just let us know if you need any further assistance
Message 10 of 15
The line in question is ADSL. You're misunderstanding a little though, all lights are normal (no red), as there has been demand but the router's WAN appears to not wake up as it should. Which is why I think it may be faulty.
As mentioned, I have enabled 'always on' which will elimate the sleep/waking process for the WAN and will post back with results.
Message 11 of 15
"Always On" only affects ADSL, do you have ADSL or VDSL?
If you have ADSL & "Always on" was not enabled, you would notice that the Internet light goes red during periods of inactivity.
However, from your previous replies, it would seem that the Internet light does not go red.
Message 12 of 15
Update - I have changed the WAN configuration to 'always on' to see if this helps.
Thought I'd mention it as I don't wish to needlessly waste any support staff time or resources.
I shall post back if issue persists and/or to inform of results in case it helps anyone else.
Thanks very much.
Message 13 of 15
Thanks for your reply, I have experience as a PC engineer so am familiar with troubles like this, it does seem to be a flakey router. Does seem to be quite common with these. Previous Netgear router was perfect. And the usual advised checks are already done.
Status lights appear normal during the drop out. And yes, wired connection affected also.
Message 14 of 15
No, it is not a known problem at all & therefore needs investigation.
1. What is the exact status of the lights on the front of the router when this happens?
2. If you have any wired connections, are they affected in the same way as wireless ones?
