Devices not receiving full speed
DanCFlake
Visitor
Message 7 of 7
The connection between my router and the internet seems to be fine (80MB/s) but when I run speedtests on my devices they're only getting around 17MB/s. Is there a router setting that needs changed?
6 REPLIES 6
Message 1 of 7
Hi DanCFlake
That's great, thanks for letting us know.
DanCFlake
Visitor
Message 2 of 7
Sorry for late reply, got really busy and didn't have time to turn on laptop again until now
The 30 minute reset worked great, thanks for your help
Message 3 of 7
Are these speed tests, if still slow, on wired (Ethernet) or wirelessly connected devices? If wireless, I can help a lot with this.
Message 4 of 7
Hi DanCFlake
How are you getting on following the 30 minute power down of the router?
DanCFlake
Visitor
Message 5 of 7
Ok will try that now, thanks
Chris-TalkTalk
Message 6 of 7
Hi DanCFlake,
Can you switch your router off and leave it off for at least 30 minutes then switch back on and retest, this should resolve the issue.
