Dlink 3782 VPN Isiues, Router login problem
10 REPLIES 10
So I got this Dlink 3782 replaced 2 times and yet still have VPN issues it connects but you can't even open a webpage It's so slow and second problem after some time the router access page does not work anymore so I can't access my settings to change things. I had a web chat with Tech they can't do anything about it so pls help
There are known VPN issues that are fixed with firmware V1.10.
However, once a VPN client connects, it is assigned an IP address from the VPN server and it is no longer on the 192.168.1.x IP network, so you won't be able to access the router's web management UI until you drop the VPN connection, this is perfectly normal.
I have asked one of TalkTalk's OCEs to pick your thread up and upgrade your router's firmware for you.
Hi shadowraven89,
I'm sorry to hear this. I've checked and the router currently has the latest version of firmware. Just to confirm, does this affect wired and wireless?
hello, Michelle thank you for the reply yes it's, either way, wifi and LAN.
I had nothing but issues with this device it works for a month, the access part that is then it locks me out.
So I can't even access my router settings so to change my wifi pass or just general stuff and then the VPN issue basically 0.010Mbps connection download takes about a good 1-3mins to open a page.
I can't remember what device I had ages ago before replacement and take note this was the 2nd Dlink 3782 that got replaced but as of now, no VPN and no access I have a brick in my house think this router needs to be scrapped.
Hi shadowraven89,
Ok thanks for confirming this. Would you like us to send a HG633 router for testing purposes?
Hello Michelle
Yes at this point I try anything to be honest, do i have to pay for this?
Hi shadowraven89
There will be no charge for this router. Please let me know if you would like me to go ahead and send the router.
Yes Please Thank you
Hi shadowraven89
The HG633 router is on its way, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with this router 🙂
Hello Debbie
Thank you very much I will let you know as soon as I set it up, hopefully, the speed issue will get fixed in the process too whenever I do a service status it's telling me (Your broadband connection could be better) but one problem at a time.
Thanks again
Hi shadowraven89
