on 30-04-2019 06:37 PM
Just wanting some advice. When I signed up to faster fibre I was told my speed would be between 29 and 40 Mbps. I am currently connected at 26 with my router connected directly to the master socket.
I am quite close to the exchange as I was connected at 15Mbps on my Adsl connection. Can someone advise? Thanks
on 03-05-2019 09:56 AM
Hi Ckell,
I've just received an update to advise that the fault has been passed to BTOR for further investigation.
on 03-05-2019 08:54 AM
Hi Ckell,
I've requested an update from our Network Team now. If you don't hear back by the end of today then please can you bump your thread and we can re-check this again for you.
on 02-05-2019 04:46 PM
@Chris-TalkTalk Still no change. Is this being looked into as the router has not lost connection for nearly 2 days when I restarted it ?
on 01-05-2019 10:52 AM
OK thanks. I've raised this to our network team for further investigation. Can you bump the thread tomorrow and we'll check for updates
on 01-05-2019 10:16 AM
Hi chris
There are no other devices or cables connected, just the router cable plugged in. I have a pre-filtered socket, so yesterday I unplugged the cover and connected to the test socket via a filter. Same speed. Thanks
on 01-05-2019 08:42 AM
Hi Ckell,
Welcome to the Community, sorry to hear that your speed isn't as expected
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
Are you experiencing any problems with your telephone service such as noise on the line?
