Eero pro 6 and fiber 65
Dilwar20
Message 6 of 6
Is it possible to use a #EeroPro6 with a standard Fiber package like the #Fiber65 as I currently have no better Fiber available where I live?
5 REPLIES 5
Message 1 of 6
Dilwar20
Message 2 of 6
I had Sky Broadband Hub and it was great when it came to putting devices on curfew and restricting Internet through an app. I was hoping I could do something similar with TalkTalk. It seems the only way of achieving this is through the Eero
Message 3 of 6
I honestly don't know. The first thing you need to consider is whether your TalkTalk Hub is providing the wireless connection you need across your home? Beyond that, I will have to defer to others.
Dilwar20
Message 4 of 6
I'm new to TalkTalk and I have been sent this router. Will I be able to use Eero 6 with this. I spoke to TalkTalk customer service and I was told Eero 6 is not compatible with Fiber 65
Message 5 of 6
It's just a router, so you will need a separate modem.
