Every other device connects normally and has internet connection apart from Laptop
paulrankin
Message 10 of 10
My fathers laptop (windows 10) connects via WiFi to his router (talk talk) but has no internet connection. All other devices connect normally and have internet connection.
Connecting the laptop with Ethernet works and has an internet connection. I have taken his laptop to my home network (virgin) and it connects normally with internet connection over WiFi.
I have forced the laptop to forget his WiFi connection then renewed the settings.
Hope someone can offer some good advice.
9 REPLIES 9
martswain
Message 1 of 10
@paulrankin if you can connect to the SSID but get a "no internet" warning, right-click the WiFi icon on the taskbar and one of the options will be "Troubleshoot problems"
Message 2 of 10
I'd just initially check that the router is visible in network and internet settings, this can be accessed via a icon on right of the task bar. Any router in range should show
Message 3 of 10
Hi Chris yes I rebooted router the laptop can see the router and connect via WiFi but has no internet connection if I remember I did get a dns error in his browser sorry I can’t check for a couple of days what should I be looking for
thanks Paul
Message 4 of 10
Yes both are valid address ranges. I would try rebooting the router if you haven't already and then search again for available networks. If other devices are connecting  to the router by wifi then it's not likely that anything has been changed on the router.
paulrankin
Message 5 of 10
Thanks Michelle
Will have another look in a couple days. But if I think logically about it as I connected with no problems on my own network that possibly points to a setting on his router not his laptop.
he has HG633 router which settings might have changed.?Only difference I can see between his and my network settings are his local ip range is 192.168.1.* while mine is 192.168.0.* but both are valid local addresses?
Message 6 of 10
Hi paulrankin,
If you search for wireless networks from the laptop do you see the TalkTalk router?
Message 7 of 10
Thank you
I already ran network diagnostics it could not fix the connection
Not really that familiar with Windows 10 most of my experience is Apple Mac
Understand there are a few things you can try to do with checking the wireless adaptor under update & security / troubleshoot/ additional troubleshooter / network adaptor
But won’t be able to run this until I visit in a couple of days
Message 8 of 10
martswain
Message 9 of 10
Run NETWORK DIAGNOSTICS on the computer.
