i’ve been with talktalk for a couple of weeks. My router after 2 days just completely stopped working. No power to the router at all tried multiple plug sockets & all other household goods were working fine on all plugs. I contacted your online chat & got nowhere so gave up. I am now using a very old router I had kicking about & it’s effecting my broadband speeds. Is there anyway this hub from talktalk can be replaced? I’ve seen others with the same issues so must be a common thing?
thanks
tom
If it is faulty, then yes TalkTalk will replace it. I have never seen anyone else with this problem with the hub, but yours does seem to have developed a hardware fault. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi Tom
Apologies for this.
I have ordered a replacement router, please allow 24-48hrs for this to arrive.
