Failed recordings
JudyO1
Message 8 of 8
2nd problem - Nothing is recording, always message Failed Recording.
7 REPLIES 7
Message 1 of 8
Hi JudyO1
Has this been working ok since your last post?
Thanks fr8ys 🙂
Message 2 of 8
Great, pleased the advice worked
Message 3 of 8
Thank you!  The full factory reset seems to have sorted it - fingers crossed.
Message 4 of 8
OK thanks
Message 5 of 8
They are not "stopping the ability to record," but they are no longer supplying recording boxes, either to new customers, or as replacements.
Message 6 of 8
Hi,  thanks for your reply.  I will try all of this soon however have I read somewhere, on this forum, that TT are stopping the ability to record, or am I imagining it??!!
Message 7 of 8
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
