Faster Broadband Speed down to 1 !!!!!!
Rochelle
Insightful One
Message 9 of 9
My broadband speed is really low. I did a speed test and it was only 10 instead of the usual 36 but the last speed test I did registered it as only 1  !!!!!  What is going on?  Upload speed is the usual 5. Have checked the service status and all appears to be OK. No outrages or anything. Anyone else got a problem?
8 REPLIES 8
Message 1 of 9
Message 2 of 9
@Skynet_TX @Chris-TalkTalk @Michelle-TalkTalk    Speed back up to 37.5  after turning the router off for an hour.  Thanks
Rochelle
Skynet_TX
Message 3 of 9
@Rochelle  Are you testing on a 'wired' or 'wireless' device ?
Message 4 of 9
Rochelle
Insightful One
Message 5 of 9
@Michelle-TalkTalk @Skynet_TX    Speed back up to 34.8 a couple of minutes ago and just done a retest and it is down to 24.3 so I will  turn the router off for 30 mins!!!
Rochelle
Message 6 of 9
Thanks for the update and please let us know if the speed does continue to intermittently drop.
Message 7 of 9
It's now back up to 25 -will keep an eye on it and maybe will reset the router as you suggest. Thanks
Rochelle
Skynet_TX
Message 8 of 9
Hi @Rochelle,
Are you running the speed test wired or wireless ?
Have you tried switching the router off for over 30 minutes to reset your session ?
