on 27-10-2020 07:10 AM
Had email last night to say my WiFi has gone live, but the light on router is just flashing Amber?
on 29-10-2020 06:45 AM
Hi Amy
I'm showing a connection now, are you able to go online ?
on 27-10-2020 02:33 PM
It really helps hugely if you can listen to the line, @Amyban. See if you can borrow a phone to plug in.
You definitely need to set up "My Account".
When you plug in the phone, dial 17070, and it should read back your phone number.
on 27-10-2020 02:19 PM
Hi, iv tried switching it off and back on, I don't have a headset to test the line, but we only switched from one WiFi provider to TT, I'm currently trying to find the letter that had the landline number on it to set up account as we do not use a land line, the light is still flashing Amber 🙄
on 27-10-2020 01:02 PM
on 27-10-2020 07:21 AM
Please complete your community forum profile details, @Amyban.
Go via your avatar/name; settings; launch profile wizard; make sure you put in your landline phone number and a fallback mobile phone number; click finish to save.
This is for staff to identify your account.
Meanwhile, try switching the router off for a full 30 minutes. See if it connects properly after that.
Only try that once, then leave it switched on.
Also check that you have a landline connection. Plug in a handset to check that the line sounds correctly.
Staff reply during the day Monday to Friday.
