Fortinet VPN connection issue
6 REPLIES 6
I have a work laptop that i've been using quite happily to connect to the work VPN for over a week now. Then today it will not connect.
I launch the Fortinet VPN Client to connect and the first clue of issues is that whenever the laptop has a connection, wired or wireless, to the router the client is slow to launch. Then when I try to connect the client says "connecting" but does not show any progress percentage at all, not even 0%. It eventually times out saying the VPN server could not be reached.
What have I done? Lots i think.
1. took the laptop into work and with a wired connection it worked fine.
2. set up a 4G hotspot from my phone and it worked fine.
3. tried a wired (eg ethernet) connection from the router...symptoms as above.
4. powered down my router for 30+ minutes... no joy.
5. done a factory reset of my router... no joy.
6. checked router fimware, latest version available already installed.
I have a TP-LINK TD-W8970 router and it's an excellent piece of kit and as mentioned above has been connecting flawlessley for over a week. All other devices connected either via wifi or ethernet cable connect to the internet just fine.
Please can you advise or help on your end to resolve this for me. Ta.
Can you access the internet OK over this wifi connection before attempting to establish the VPN connection? The normal problems with VPN are TalkTalk router or DNS related, but as your VPN has only just stopped working and you have a TP-Link router, something else is causing this.
Hi Keith,
when I connect to my works VPN I then use Citrix applications rather than local ones installed on the laptop. When I've got the hotspot connected and I try to get to www.google.co.uk for examplewith the local browser in the laptop I get "the proxy server is not responding - check your settings: ****proxy_lan.live.internal:8080" (I've hidden the bit under the **** as it's my company name).
If I connect with a wire at work I can use the locally installed browser just fine because the proxy is present.
This is as annoying as heck.
EDIT: I also should mention I already had Scam protection etc disabled.
I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you. Under the circumstances, this is about all I can really do.
Hi John
I'm unable to connect to your router, please can you factory reset the router using the pin hole reset for 10 seconds?
Hi Debbie,
I don't know why you couldn't see my router as it's always on. I did a factory reset yesterday, see point 5 in my initial post.
Anyway, the problem seems to have resolved itself as I was able to connect to the VPN again via my routers wifi at approximately 3pm yesterday finally.
I don't like it when issues 'fix themselves' as they generally come back later, but we'll see.
If it happens again I will start a new thread and link back to this one.
Thanks,
John.
glad its fixed.
