HG 633 Empty System Log
ChrisRicha
Message 7 of 7
I have not changed anything but noticed that my HG 633 router now has no entries in the System Log.
Anyone any ideas why this might be?
6 REPLIES 6
Message 1 of 7
Yes I guess that is the next step. Will do when I have time.
Thanks for your help
Message 2 of 7
Are you saying that there is no Device type & Device level dropdown boxes present then, rather than just no entries? If so please carry out a factory default of the router's configuration.
Message 3 of 7
The sys log page is empty. No table with selectable categories as usual.
chris
Message 4 of 7
In the system log settings, what severity level do you have it set to, e.g. warning, information debug etc?
Message 5 of 7
Keith thanks for your reply
There have been no chenges made by me. The firmware is v2.00t.
Up-time is 5 days ( had some problems with faulty Hive hub).
Message 6 of 7
Has the firmware recently updated or the configuration been set back to default?
