Have a router. Need to sign up.
7 REPLIES 7
I just moved to a new property. The previous tenant used TalkTalk's broadband and wifi. He cancelled the contract. I still have the router. I just need a wifi. Can I sign up and activate without an engineer needing to come in?
you may need to place a new order online.  If no access is required to your property and there is an existing line then BT Openreach can connect at the exchange.
Hi, thank you for your reply. What should I do in that case?
Hi risenea94
Did you try placing an order on the website?
No, I haven't yet. Is it 100% guaranteed if I place an order online that I will have a broadband without an engineer needing to come for my activation (given that I have a TalkTalk router and landline)?
Enea
Hi Enea
We can't guarantee if the engineer will need to do any work within the property when completing the install. If this is the case then this would be delayed until June.
But if I already have a TalkTalk's hub and a landline, why would an engineer need to come?
Hi risenea94,
There could be a fault that's only apparent when the service goes live. Unfortunately, as stated above, we can't guarantee that a engineer won't be required
