How do I turn Scam Protection off?
MattyL
Message 8 of 8
I have recently moved over to Talk Talk and am having real problems. I use Teamviewer and Splashtop for work but cant access either now due to the scam protection.
I have tried to call twice, both times i was assured it was disabled, after waiting on hold for a good 10 minutes (presumably to run checks to make sure i wasn't in a far away land) but still no joy!
This is impacting my work and really isn't very helpful!
Some days you're the Pigeon, Some days you're the Statue......
7 REPLIES 7
Message 1 of 8
Hi Jedward,
I'm sorry to hear this. Please can you create your own thread and we can look into this further for you.
Message 2 of 8
I also have been trying to turn Scam Protection off in order to operate Team Viewer. The off tab simply doesn't work. Numerous e-mails and phone calls to Talktalk have had no effect. Can anybody help?
Message 3 of 8
I checked the info with Ady, all is now done.
Message 4 of 8
Thanks Karl, I have PM'd Ady with the details required
Message 5 of 8
Hi MattyL
PM's should mow be enabled for you.
Message 6 of 8
Hi, I dont seem to have a PM?
Where do i send my info to? i'm really struggling with this now!
thanks
Ady-TalkTalk
Message 7 of 8
Hi MattyL, I can turn scam protection off for you. I've sent you a Private Message so that we can do security checks and then get this sorted for you.
