How long does it talk to optimise a line
Raheela Iqbal
Message 2 of 2
Problem with my broadband speed
1 REPLY 1
Message 1 of 2
When a new line is connected BT ask to allow 7-10 days for a line to fully optimise so the DLM system has a chance to build up a 'data' history to consider when setting the required profiles.
If the line has been live for a while, then DLM should be optimising the line over 24hrs.
Are you having an issue with your service or connection currently ?
If you add your home phone number to your Community Profile we can take a look.
