How to get a replacement router
sabresofparadise
Message 5 of 5
Hi all, just wondering if it is possible to get a replacement router? I've just returned home after a couple of weeks away to find my router light turned off when it's always left on.  I tried turning it back on, I have plugged other devices in to the socket and they have worked without problems, I have also tried plugging it in to other sockets with no joy.
Any help appreciated, thanks in advance.
4 REPLIES 4
Message 1 of 5
Hi sabresofparadise
That's great, thanks for letting us know.
sabresofparadise
Message 2 of 5
Hi, all sorted now thank you
Message 3 of 5
Hi sabresofparadise
Skynet_TX
Message 4 of 5
Hi @sabresofparadise,
If your TalkTalk supplied router appears to have died then the staff here will be able to help, they should be able to reply to this post tomorrow and will be able to arrange a replacement router for you.
