Huawei DG8041W - V1.05
Divsec
Message 18 of 18
Hi I'd be very grateful if you could update my router to latest version (may well have happened overnight), and then check my connection it seems to be progressively by slowing down.
Unfortunately not possible to use master socket as for some obscure reason it is located in a very bad location.
Many thanks in advance
D
17 REPLIES 17
Divsec
Message 1 of 18
Thanks for your help everyone, the modem element on my Draytek, 3yr old, packed up this morning, so back on with the Huawei and bleed all over Draytek to see if they will fix it. Good shopping opportunity if nothing else
Divsec
Message 2 of 18
Hi @Karl-TalkTalk thanks for checking this out for me. Now all that remains is to endure the earache from senior management won't be pretty.
Message 3 of 18
All looks ok here, I've had a look at all the voltage and capacitance levels across the line and all are fine.
I'd initially suspect the socket or internal wiring as no issues can be seen from this side.
Divsec
Message 4 of 18
Hi @Chris-TalkTalk well tried that with my Draytek router and sad to say it went downhill.
When you have a chance would appreciate your thoughts, I get the feeling I might be master socketing which will be a pita
All the best and thanks
D
Message 5 of 18
Divsec
Message 6 of 18
@Chris-TalkTalk will do thanks Chris I'll pop it on this evening
Message 7 of 18
OK, do you have another router that you can test with, just leave connected for a couple of days to see if DLM moves you to a faster profile?
Message 8 of 18
@Chris-TalkTalk telephone is fine thanks Chris
Message 9 of 18
Is your telephone service OK? (line test is passing but DLM has moved you to a slower profile)
Message 10 of 18
@Chris-TalkTalk just router and 1phone
Message 11 of 18
OK thanks, do you just have one telephone and the router connected or do you have other devices connected?
Divsec
Message 12 of 18
Hi @Chris-TalkTalk 5 or so I'm afraid. The master socket is in a powerless location and extremely wife unfriendly to use.
Message 13 of 18
Hi Divsec,
As Keith has said v1.05 is the latest firmware version for your router. Your speed is a bit low though. How many telephone sockets do you have?
Divsec
Message 14 of 18
Hi @Michelle-TalkTalk how good am I! Sorted sorry 😢🤦‍♂️
D
Message 15 of 18
I'm sorry to hear this. Can I just confirm, is the telephone number in your Community Profile correct? Please do not post any personal information on the Community.
Divsec
Message 16 of 18
Thanks @KeithFrench yes understood I just wanted everything tickety boo so when the the guys get to the second part of my request they had 1 thing less to concern them
D
Message 17 of 18
Hi @Divsec
All that V1.06 does is fix an issue where the router keeps restarting & if you look in the User Log, you would see that it has restarted due to a kernel panic.
