I cannot get my VPN to connect through my broadband
7 REPLIES 7
I use Tunnelblick to connect to a VPN for work, right now I am working from home but cannot use my broadband to connect to the VPN. I know that this is a problem with the router/ISP because it works correctly if I tether to my phone and use the mobile connection.
Hi mthorning
  • Name
  • Telephone number
  • Alternative contact number
Hi, I have updated my details. I have also got things working by changing my hosts file to point at the IP addresses which I am visiting via VPN. Is talktalk doing something which affects DNS lookups through VPNs? I have a colleague who experienced the same issue on talktalk, other colleagues with different ISPs are not having to change their hosts file.
Hi mthorning
I've checked and your router has the latest firmware version and this should work ok with VPN.
We do suggest trying to split the SSID's (if you are unable to connect)
You could try splitting the SSIDs on your router and testing the connection between the 5gh channel and the 2gh channel, some devices operate better with just 1 channel selected.
Log into the router  (192.168.1.1 etc ) and manually change the SSID (Wi Fi) name of the 5ghz channel.
I often find it is better to keep the 2 broadcast channels separate.  For example, I have changed mine, and call one Home2Ghz and the other Home5Ghz.  Some devices can drop the connection when the SSID's remain the same.
Also, you can try manually setting the wifi channel  for each broadcast channel. Try channel 6 for the 2ghz channel and 44 for the 5ghz channel.
Give this a try , test with both SSID's and see if the connection improves.
I'm already running with the split SSID because I have a wireless plug which only works on 2.5ghz. I could try switching channels but my internet speed is good and changing /etc/hosts would not have any effect if the channel was causing the issue. As I said, I've fixed my issue now but I feel like I shouldn't have to do what I've done, I think TalkTalk is doing something funny because I'm not the only person with this issue.
Hi mthorning
We don't do anything to stop VPN from working. Which VPN client are you using? I can then ask our Products Team to take a look at this.
Ok, sure, thanks. I'm using Tunnelblick which I think uses openVPN underneath
Hi mthorning,
Thanks for confirming this and I've passed your feedback on to our Products Team.
