IP Addresses
DJJohhnyJetson
Whizz Kid
Message 5 of 5
Good afternoon.
I am enquiring as to whether Talktalk now uses fixed IP addresses on their services, also if they do, am I one of those lucky people that has a fixed IP.
If I am not fixed IP, is there any way that I can find out the last few IP addresses for my service over the last 2 months.  Its to do with a case my partner is going through with her employers, where they state she has worked remotely, and have said she has done something from her computer at home and they have an IP address that she did the said deed with.  My router only holds a limited log and only shows me the current IP address that I am using.
Thank you in advance
John
4 REPLIES 4
Message 1 of 5
You should be able to set your router up as a DDNS client & subscribe to a DDNS provider where you allocate yourself a DDNS domain. This keeps track of IP address changes & someone from the internet uses that domain name to devices connected locally to your router.
Message 2 of 5
OK John, glad to hear that you've managed to find the information
DJJohhnyJetson
Whizz Kid
Message 3 of 5
Hi Chris.
Thanks for the information, I think I've found the address anyways, as my router is not a Talktalk one, it has a more extensive log, took a bit of reading, and an IP trace website, I think I have found the information that I need.
Thank you again, but if you can try to find out for future information, it would be very much appreciated.
John
Chris-TalkTalk
Message 4 of 5
Hi John,
You have a dynamic IP address but the IP address would only usually change on fibre if you switch your router off or the connection drops for a length of time. To be honest I'm not sure if we can provide the IP addresses as this isn't something that I've ever been asked for.
