Intermittent Broadband
mjb2112
Message 6 of 6
I am in the AB56 postcode area and have been getting intermittent broadband, with it going off for 20 seconds at a time, sometimes 4 or five times an hour. Yesterday (4th August), it was also off for an hour from 11am and 5 hours from 5pm to 10pm. I switched my router off ovenight, it came back on again, but there has still been 4 or 5 short periods of downtime in an hour period. Not conducive to online meetings or music streaming.
5 REPLIES 5
Message 1 of 6
No Problem 🙂
mjb2112
Message 2 of 6
Many thanks for this information
Message 3 of 6
Your line is affected by an outage. An incident is raised for this and our engineers are working on this currently.
Message 4 of 6
Many thanks for this, I have updated these details.
The issue is still ongoing, intermittent, three outages during a 16 minute Teams meeting, not good
I have done the line tests and they say everything is ok
Skynet_TX
Message 5 of 6
Hi @mjb2112,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
