Internet drop out
52 REPLIES 52
tonyj
Chat Champion
The last time I had this issue was early 2018 and was remotely fixed by your OCE. My internet has been randomly dropping out accompanied by a red light on the router. Sometimes it will come back up on it's own, but at other times I have had to reboot the router. I have carried out a speed check and Service Status Check and the result that came back was 8.8Mb download and 0.8Mb upload. This is compared to 12Mb download last year. The Service Status came back Our health check on your service shows that your speed to your router could be improved.
Is this an issue that can be resolved again remotely?
Kind regards,
TonyJ
OCE_Michelle
Hi tonyj,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. Is the voice service ok with no noise on the line? Does your master socket have a test socket? How often are you rebooting the router at the moment?
tonyj
Chat Champion
Hi Michelle,
Thank you for your rapid response.
The voice service is OK with no line noise.
My master socket does not have a test socket.
Rebooting a couple of times per week. In fact it dropped out a little while ago, but that might have been you testing so I left it and it came back within 5 minutes or so.
Kind regards,
TonyJ
OCE_Karl
I've reset the port and profile.  See if this is stable over the course of this evening.
tonyj
Chat Champion
Thank you Karl, will do. (presumably the 2 drop outs within the last 15 or so minutes are a result of your resetting?)
TonyJ
OCE_Karl
Yes, the 2 drops were me resetting things this side.  See how things are with these changed 🙂
tonyj
Chat Champion
Thanks will do.
OCE_Michelle
Hi tonyj,
How have you found the stability since your last post? 🙂
tonyj
Chat Champion
Good morning Michelle,
I have not used the internet much since then, all ok at the present but I will monitor through the course of today and keep you posted.
TonyJ
OCE_Michelle
tonyj
Chat Champion
Hi Michelle,
Stability has been good for the last 24 hours. I ran a speed check and notice that the speed is lower than before (6.3Mb download & 0.8Mb upload)
A service check also came back with the following :-
Kind regards,
TonyJ.
OCE_Michelle
Hi tonyj,
Thanks for the update. I've checked and I can see that DLM has increased the speed this morning. Could you retest and let us know how the speed compares now.
tonyj
Chat Champion
Hi Michelle,
I have carried out a speed test, and as you say, it has increased to 9.6Mb download & 0.9Mb upload. Stability still appears to be ok, but strangely, when I run a health check, the result still comes back as poor stability and lower than expected speed?
Kind regards,
TonyJ
OCE_Chris
Hi tonyj,
Your connection appears to have been stable since the profile change, could you monitor your connection over the weekend and let us know how it's been on Monday
tonyj
Chat Champion
Hi Chris,
Yes of course, no problem.
TonyJ
OCE_Chris
OK thanks, look forward to hearing how you get on, have a good weekend 🙂
tonyj
Chat Champion
Hi Chris,
As requested :-
stability over the weekend seemed to be fine with no drop outs.
Speed test today is the same as last week (9.6 & 0.9)
Still odd, the service status test still comes back with yellow warning triangles for stability and speed?
Kind regards,
TonyJ
OCE_Debbie
Hi tonyj
Your line is showing in sync for just over 3 days at 11.4mb. We can try a line optimisation again to see if the speed increases any further. Would you like to test this?
tonyj
Chat Champion
Hi Debbie,
Not sure if my reply from my phone came through, but in case it didn't, yes please I am happy to try a line optimisation.
Kind regards,
TonyJ
OCE_Debbie
Hi TonyJ
Your line is now showing in sync for just over 4 days and 13 hours.
I have optimised the connection and DLM will be monitoring the connection and hopefully making further changes over the next 24hrs.
Please can you post back on this thread tomorrow and we can check the connection stats again.
