on 25-12-2018 01:03 PM
Not sure how to report this issue so I've come here.
I play online gaming via the computer and over the last few weeks the internet will drop for a few minutes then come back on. This will happen constantly throughout the night which makes the games unplayable.
The internet goes from the ethernet and when I check on my phone its gone from wifi too. Service status page says everything is ok.
The last provider had similar problems with my line because my house was too close to the box on the street and they needed to adjust some things.
How do request for someone to look into my line?
on 18-02-2019 12:22 PM
Hi atheena
Just to confirm, have you tested with 2 different routers at the test socket? I can then pass this fault over to our Network Team for investigation.
on 18-02-2019 12:01 PM
d LINK DSL-3782
I am sure the problem is a voltage related problem and will require an engineer with his fancy machine to check the voltage and adjust it. I had the same problem with Virgin and it was fixed within a week, engineer sent out immediately.
on 18-02-2019 12:00 PM
What I said was relevant to the original poster of this thread. They were being offered a new router and I was asking what was the point of doing that if it was the same router. They clearly need proper technical support and judging from my own experience there is a reluctance in the organisation to admit to when they are not up to the technical specification of what they've sold customers.
on 18-02-2019 11:55 AM
on 18-02-2019 11:39 AM
Oh, dear looks like I have had my last reply deleted. Did it contravene the community guidelines in some way?
I don't see how truth can contravene community guidelines so I will try again.
I also was sent out a new router and it made no difference whatsoever - why would you even suggest it?
Moreover, there was no subsequent follow up by Talk Talk - even after they promised to send another engineer up. All the chasing had to be done by me.
I also mentioned that Talk talk had the second highest number of recorded complaints last year through Ofcom. I don't think that's anything to be proud of and it sounds to me that there must be systemic technical failure at the company, mirrored by the customer service - which is all about reading out computer says no scripts, from either Manilla or South Africa.
on 18-02-2019 11:04 AM
Hi atheena
I can send a replacement router for testing. Just to confirm, which router did you receive previously? (make and model)
on 18-02-2019 11:00 AM
Wow, sounds like you are having a really bad experience.
I had to end up cancelling my contract with Talktalk. They were unable to provide the service they had sold me.
They also tried everything in their power to charge me the cost of the contract on exit even though it was entirely their fault.
The customer service was also appalling - being bounced between Manila and South Africa endlessly. I had to escalate upto senior manager level.
on 18-02-2019 10:50 AM
After trying other equipment, I'm still getting the couple of minute disconnects throughout the day.
If you think the new router will help, I will give that a go. I am a relatively new customer, would you have supplied me with a new router when I joined a couple of months ago or are they re-cycled old ones that are sent out to new customers?
on 17-01-2019 06:05 AM
Hi atheena,
Thanks for confirming this. I've included a Help Article below.
on 16-01-2019 03:58 PM
I have a brand new tp-link AC1750 dual band router, could I use that? or do I have to use the ones supplied by talk talk?
on 14-01-2019 07:06 AM
Hi atheena
I can send a replacement router for testing, would you like me to arrange this?
on 13-01-2019 11:16 AM
Thanks for the reply. I've only just joined talktalk so all the equipment and cables are new.
I've been getting a lot of disconnect recently. In a catch 22 situation, can't log on to let anyone know it's happening without internet connection.
When I do a troubleshoot the most common error message I get is DNS server isn't responding. Not sure how or why this happens.
on 28-12-2018 06:08 AM
Hi atheena
I've checked the connection stats again this morning and the line is now showing in sync and connected for 1 day and 22 hours.
If you do experience any further issues then please post back on this thread and we can investigate this.
on 27-12-2018 03:53 PM
Christmas eve was a really bad day for the connection. The connection in the past day or so has been good.... just as I ask someone to look into it.
on 27-12-2018 01:26 PM
Hi atheena
Thank you for updating your Community Profile.
Your line is showing in sync and connected for just over 1 day and 5 hours.
When did you last experience a drop in connection?
on 27-12-2018 12:21 PM
on 27-12-2018 07:23 AM
Hi atheena
on 25-12-2018 02:19 PM
Hi @atheena
