Internet drops when using TV or chromecast
sitaindra
Message 4 of 4
I have found that whenever I use any of the apps on my You view box  e.g Now TV or cast from my phone to my chrome cast I get a drop in connection every 20 to 30 minutes for 2 minutes or so before it reconnects.
I never have this problem if I just use my laptop for work and my phone to watch things but its getting annoying that this keeps happening when I want to watch on my TV. I have done line tests but they have all come back fine, reset the router and it still happens.
Has this happened to anyone else?
Sita
Sita Indrakumar
3 REPLIES 3
Message 1 of 4
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
sitaindra
Message 2 of 4
Yes the box is connected directly to the router and it starts to flash orange when the drop happens. I have tried the pin reset but it is still happening.
Thanks!
Sita Indrakumar
Message 3 of 4
Is the Youview box direct to the router with a cable or via powerline adapters ?
When the drop happens, does the light on the router flash ?
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
