Internet keeps disconnecting
Rmorais
Message 6 of 6
Hi, my Internet disconnects about 2-3 times a day the white light turns red and blinks and then it reconnects again. However when it does reconnect I have to physically turn router off and on again  as even though it has a white light there is still no connection. Today its been blinking orange for the past hour and hasn't reconnected, I restarted router and now its working again. Please advise what the issue is. This has been happening for a few months now. And I'm just getting to the point where I'm fed up having to keep switching router on and off. Please help
5 REPLIES 5
Message 1 of 6
Hi Rmorais
Message 2 of 6
Yes please
Message 3 of 6
HI Debbie,
Yes please at this point I will try everything.
Kindest Regards
Raquel Morais
Message 4 of 6
Hi Rmorais
I've completed a line test which hasn't detected any faults.
Would you like me to send a replacement router for testing to see how the connection compares?
Skynet_TX
Message 5 of 6
Hi @Rmorais,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
It could also possibly be a fault with your router, the staff here will be able to take a look and if they did feel this was a router fault they would be able to arrange a replacement for you. They will hopefully be able to respond to this post tomorrow.
