on 22-10-2020 11:44 AM
I have a DLink DSL-3782 router. For the past few days it has been frequently disconnecting from the internet. What normally happens is that I notice that the internet access symbol in my PC notification area will indicate I have no connection. I look over at the router and after a while the router Internet light goes red. I've tried restarting the router but the behaviour continues. Sometimes the connection works fine for a long time (e.g. I was using it all last night with no apparent problems), but eventually it will lose connection again. Sometimes it comes back of its own accord, but often with a connection so poor that I can't use it. After a short while it will drop again. One more thing; if I plug in a computer with an ethernet cable it still doesn't work. It's a strange problem. I wonder whether anyone can help me with it? Thanks.
on 28-10-2020 01:02 PM
Replacement router on the way for testing.
on 27-10-2020 12:23 PM
Hi Debbie. Perhaps you better had send out a router. I thought I had a good workaround when I set my router internet configuration to Always On (it had originally been set to On Demand). That worked fine for a couple of days, but now it's playing up again. Thanks.
on 26-10-2020 10:18 AM
Hi TTC2020
I think we should send a replacement router for testing, would you like me to arrange this?
on 23-10-2020 09:46 PM
Lost connection again at about 2130.
on 23-10-2020 08:39 PM
18 minutes later and it seems to have fixed itself again. Fingers crossed.
on 23-10-2020 08:35 PM
Okay. Last night I updated my profile with name, landline and alternative number. My connection then fixed itself, which it has been doing off and on. I have been home this evening. My connection has just dropped again (at about 2020), so I'm back to using my phone as a router. The TalkTalk router says the uptime was 3 hours 28 minutes 9 seconds, which probably corresponds to when I got back in and my phone got onto the wi-fi. I'd be very appreciative if someone from TalkTalk could shed some light on this, because I'm stumped. Thanks.
on 22-10-2020 10:14 PM
Thanks. I went to the Service Centre and did a test on my line earlier on. It didn't find any problems with my line but told me I needed to check my set-up at home. I followed the procedure it gave me and ultimately it asked me to restart my router, which I did. After that it worked fine for hours, but it has now dropped the connection yet again at 2205 (I'm using my phone as a router now). I will therefore follow your advice so I can get some help from TalkTalk staff.
on 22-10-2020 08:21 PM
Hi @TTC2020 ,
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line that might be causing your router to keep losing connection. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within a day or two.
