Internet keeps going down
Tristan2
Message 3 of 3
Keep loss sing Internet
Message 1 of 3
Hi Tristan2
If you can answer the questions above, that will give a little more information to allow us to look into this for you.
Skynet_TX
Message 2 of 3
Hi @Tristan2,
Do you know if the problem is with the router losing its connection to the internet (in which case a light on your router which is normally constantly lit will change colour or flash), or is it that you are losing Wi-Fi connection between your device(s) and your router (in which case the light(s) on the router will just carry on looking normal).
Do you have any ‘wired’ devices, do they also lose connection ?
