Is there a way to monitor how much bandwidth is being used at any given time, and by what?
1 REPLY 1
I regularly use the Microsoft xbox app on my laptop to stream games from my console to my PC on my home wifi.
Most of the time this works flawlessly, and my laptop is more than sufficient to run the app, but occasionally the stream is really poor quality, pixelated and there's a delay, despite the internet speed showing at 25-30mb.
Is there any way that I can see which devices on our network are using the most bandwidth at any given time - some kind of traffic monitor? I'd like to see if I can figure out what else is using the bandwidth when the streaming is poor, to try and work out what's causing it.
Thanks!
We dont have any TalkTalk applications that do this, but im sure there are some downloadable apps that can do this for you.
