on 11-06-2021 03:14 PM
Having trouble again with router not being stable, router will not stay on the channel selected. I have sent 2 PM messages to OCE Debbie who help me out last time.
on 21-06-2021 01:06 PM
You're Welcome 🙂
on 21-06-2021 12:56 PM
Hi Karl,
Many thanks for quick reply, I will now tweak the router to my requirements. have a good day.
BBUK1st
on 21-06-2021 10:36 AM
optimisation is now off.
on 21-06-2021 10:25 AM
Hi Karl,
I have now received the replacement router, would you or one of the OCE's please turn off WiFi optimisation. I have left all the settings to the default. Thank you in advance
BBUK1st
on 16-06-2021 01:00 PM
You're Welcome 🙂
on 16-06-2021 12:55 PM
Hi Karl,
Thank you very much for your help, please have a good day.
BBUK1st
on 16-06-2021 12:13 PM
i'll swap out the router and see if this is better.
on 16-06-2021 11:57 AM
Hi Karl,
Thanks for getting back so quickly, I manually set the channel each time.
BBUK1st
on 16-06-2021 11:08 AM
Have you manually set the wifi channel or have you set it to Auto. We can turn off wifi optimisation, but the router can also be set to Auto channel selection from your side, Can you check you have not got this set to Auto. If it is not set, then it is possible there is an issue with the router.
on 16-06-2021 10:51 AM
Hi Karl, since you turned off Wi-Fi optimisation the router has reset the channel to the default 4 times now. I left all the settings to the default except the password and only change the Wi-Fi 5Ghz channel. Could the router be faulty?
BBUK1st
on 14-06-2021 04:57 PM
When a router is reset, it will usually default to on and we just need to sync the settings with our ACS (TR069) platform. It still shows as off, but we need to resync the settings,
on 14-06-2021 04:33 PM
Hi Karl, thank you for turning off the wifi optimisation, is there any reason why it was switched on again as debbie OCE turned it of over a month ago.
Once again thank you for your help.
BBUK1st
on 14-06-2021 03:59 PM
optimisation is now turned off for your router.
on 14-06-2021 02:54 PM
Hi Steve thank you for taking the time to reply,
Your suggestion to “turn off” auto is not an option in the Sagecom Fast 5364 Router and Wifi Hub, however the option is “below” or “above” (the selected channel) I have tried both options over the weekend and nether of them held the channel. Debbie OCE has replied to me and is now trying to sort it.
Thank you once again
BBUK1st
on 14-06-2021 02:40 PM
Hi Debbie, thanks for getting back to me, i have reset the router back to factory settings, and await your retry of wifi optimisation again. Thanks for your help again.
BBUK1st
on 14-06-2021 07:29 AM
Hi BBUK1st
I'm unable to connect to your router, please can you factory reset your router using the pin hole reset for ten seconds, I can then try and connect again.
on 11-06-2021 09:46 PM
on 11-06-2021 03:44 PM
on 11-06-2021 03:28 PM
