Line drop causes Ethernet ports to stop working
5 REPLIES 5
When the line drops once or twice a week this results in all hard wired ethernet devices failing
The fix is to reboot the router but this isn't a long term solution
Would it be possible to get a new router for testing
Kind Regards
Andy
Andrew Ditchburn
Hi @Athulla ,
For one of the TalkTalk OCE's on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number & alternative contact number. This will allow them to identify you, and they will then be able to help. If they think the router is faulty they will be able to send you a replacement.
Hi I have updated my personal details
Andy
Andrew Ditchburn
Can you add the home phone number to your 'Community Profile' rather than the mobile so I can locate your account.
Hi Karl,
Sorry i have put the landline on..Never use it!
The connections been dropping off once a day at different times
It wouldn't a problem if the router could reset itself but it needs a phyical reboot
Cheers
Andy
Andrew Ditchburn
Hi Andy
Apologies for the delay.
