Losing internet
Kscout2
Message 11 of 11
For some weeks I have been losing internet when connected via wifi. All is o.k. via ethernet connection. Tried resetting router several times. Problem persists. This happens on four devices.
10 REPLIES 10
Message 1 of 11
Hi Kscout2
Kscout2
Message 2 of 11
Thanks Karl, fingers crossed.
Mel.
Message 3 of 11
I've a router on the way to you so we can rule this out as a potential cause.
Message 4 of 11
Yes dial tone present and calls appear o.k. Router log is showing 53M connection but a tremendous amount of errors on wireless access.
Thanks,
Mel
Message 5 of 11
Did you have a chance the test the voice service to see if there is a dial tone or any noise on the line please as this can affect the broadband connection?
Message 6 of 11
Hello Debbie, I'm having great difficulty with all of this, I've now connected everything via the main socket. Problem persists, please could you do another line test please?
Message 7 of 11
Hi Kscout2
The line test is detecting a potential landline fault. Are you experiencing any faults with the landline service? (noise on the line)
Message 8 of 11
Hello I've updated profile. The roter is a Huawei HG633. I've tried all thes suggestions multiple times but the problem persists. As I said earlier connections via ethernet are perfectly o.k. I'm not losing the wifi signal at all, just bthe internet.
Thanks, Mel.
Message 9 of 11
Hi Kscout2
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this for you.
Skynet_TX
Message 10 of 11
Hi @Kscout2,
What make / model of router do you have ?
There are a few things you could try to see if it is Wi-Fi interference causing the problems.
Split the SSID's on the router, this will allow you to give the 2.4GHz and 5GHz network bands different names, so your Wi-Fi devices will then see those two networks separately, you can then try connecting to one or the other to see if one gives a more reliable connection than the other. Doing this in itself won’t fix the problem, but it makes it easier to troubleshoot as you can easily see what device is using what band.
Change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
If trying the above makes no difference then it may indicate an issue with the router, the staff here would be able to help with that.
