Low speed and losing connection
Robin
Message 32 of 32
Hello, I've got very low speed internet especially in evenings last 7 days. Sometimes I'm losing connection. For me is very annoying because this is the time for my daughter watching cartoons. Can anybody give me a contact for someone who's going to fix it please? I don't want to pay money for nothing.
Thank you and have a nice day.
Robin
Robin
31 REPLIES 31
Message 21 of 32
Hi @Robin ,
Info on how to tell if you have a test socket, and how to access it can be found here : https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432
Message 22 of 32
Sorry but I don't know what is test socket so probably not. But I can see router in wifi search but there is no connection to internet. So in router is electricity.
Robin
Message 23 of 32
Hi Robin,
If the connection is unstable then this can affect the speed. Does your main socket have a test socket as we will need to look at the stability first?
Message 24 of 32
But the speed is 35mb/s and it should be around 60 I think.
And another question is why the speed od my device is only half speed? I've done measuring couple days ago and it was 60 on router and 30 on device. Why?
Thank you for response.
Robin
Robin
Message 25 of 32
It's working now. For a while
Robin
Message 26 of 32
Hi Robin,
I'm sorry to hear this. I've re-run the line test now which is still clear, however I can still some re-connections on the line. If the main socket does have a test socket then if possible please can you connect the microfilter, router and phone at the test socket so we can see how the stability compares. If the connection is still unstable following this then we can send a replacement router for testing purposes to rule this out.
Message 27 of 32
By the way today I'm without connecting all day. I have to text you with mobile internet. Such a lovely day. When you need broadband for work.
Robin
Message 28 of 32
Photos are dated
12.05.21 - 17:51,19:36
13.05.21 - 11:23, 12:02, 13:08
17.05.21 - 13:08, 14:23, 15:00
18.05.21 - 19:05
19.05.21 - 12:27
And many times I haven't took a picture. I just went away from internet.
It's annoying when I can't do nothing without lost connection every day in any hour.
Robin
Message 29 of 32
Hi. I've got many pictures of lost connection while I was working or watching something on YouTube in last 7 days. I can send you the pictures on your email address. Just give me an address please.
And the problem is about last three weeks. So I'm paying you money for nothing.
Socket is OK. That reconnections was because I was trying everything to have a connection for which I pay.
Thank you
Robin
Message 30 of 32
Hi Robin,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault, however I can see some re-connections on the line. Does the main socket have a test socket?
Skynet_TX
Message 31 of 32
Hi @Robin ,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
Do you know if the problem is with the router losing its connection to the internet (in which case a light on your router which is normally constantly lit will change colour or flash), or is it that you are losing Wi-Fi connection between your device(s) and your router (in which case the light(s) on the router will just carry on looking normal).
Do you have any ‘wired’ devices, do they also lose connection ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
