Modem router 5364 PORT FORWARDING ISSUE. IS UPNP AUTO ENABLED?
Badgershedge
Message 7 of 7
Unable to open port 44158 no matter what i try. Seems like this router might have uPNP enabled and no way to turn it off.
Any ideas?
6 REPLIES 6
Message 1 of 7
UPnP is definitely configurable in V130.
Badgershedge
Message 2 of 7
Yes thats the same one I use,  I'll check the device( does not use static config.) I'm sure you used to be able to turn upnp on and off at will. Wonder why they removed it?. Hopefully it will return in v130.
Message 3 of 7
The fact that UPnP cannot be disabled until firmware V130, will not affect manually configured Port Forwarding.
This is the rule I used & I tested it on two different PCs & it opened fine:-
If yours is the same, then this would point to a possible configuration issue on your device that you are trying to forward this port to. How does it get its network configuration, automatically via DHCP or is it statically configured on this device?
Badgershedge
Message 4 of 7
its tcp
Message 5 of 7
Yes of course @Michelle-TalkTalk, I did ask @Badgershedge to create this thread.
I have tried this with another customer trying to forward the same port & it worked first time on my laptop. I am waiting on that customer to tell me if port 44158 is TCP or UDP, as that will affect how you test it.
Message 6 of 7
@KeithFrench - Would you be able to offer any assistance please?
