My FAST5364 router will not save wifi channel settings
Kazzie1
Message 2 of 2
Hi team, Occasionally I get problems with my wifi signal and changing to a channel other than 1,6 or 11 helps enormously, but the channel reverts back and the problems reappear. This is really annoying and I want the router to save the channel which I select please. I understand there is an optimisation feature which can be turned off or disabled remotely by Talktalk and I would be grateful if you could do this for my router to enable it to stay on the wifi channel which I select and save. (serial no. N7182014N006161)
Thank you.
1 REPLY 1
Message 1 of 2
This should be turned off for you now.
