My broadband keeps disconnecting
32 REPLIES 32
IngaV
I've had broadband with talktalk for 2-3 years. Mostly fine. About 2 weeks ago it started cutting out. The router red light comes on and there's no connection. Redirects me to a "lets get you set up" splash page.
router : HG633
OCE_Michelle
Hi IngaV,
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
IngaV
I did.
I just lost connection 3 times while updating my profile and answering to this post..... Just so frustrating.
OCE_Debbie
Hi IngaV
Apologies for this.
Please can you also add your TalkTalk telephone number to your Community Profile.
IngaV
It's never used but sure. I did.
IngaV
Yesterday I was chatting to live support and I was told to disconnect everything for 30 minutes to generate new IP address, I dit that... That fixed it for about 2 hours I had stable connection and then it started dropping again.. even worse then before.
OCE_Debbie
Hi IngaV
I've completed a line test which has detected a possible fault. Would it be possible to make a call using your landline to check this is working ok? (any noise)
IngaV
Unfortunately I don't have anyway to check that.
OCE_Debbie
Hi IngaV
If you are experiencing a fault with the landline service then this can affect the BB connection and has to be investigated first.
Would it be possible to borrow a phone just for testing purposes?
IngaV
Sorry, I just checked with my neighbors they dont have one either.
Now when I lose connection, the internet light doesnt go red it just says your connection is not private and doesnt let me access any websites.
OCE_Debbie
Hi IngaV
I can see re connections on the line.
Do you have a different router that you can test with at the test socket?
IngaV
I don't have another router.
OCE_Debbie
Hi IngaV
I can send a replacement router for testing, would you like me to arrange this?
IngaV
When ever I get a replacement router it's the same thing. It's just to delay the process of actually fixing it...
But sure, why not... If that dont work, I'm just going to leave, nothing but issues with talktalk
OCE_Debbie
Hi IngaV
Ok I can raise this over to our Network Team. Just to advise if you are experiencing a fault with your landline service then the BB engineer may not be able to resolve this fault and this may then require a different engineer visit.
Are you happy for me to raise the intermittent connection fault over to our Network Team for investigation?
IngaV
yes
OCE_Michelle
Hi IngaV,
I've passed the intermittent connection over to our Network Team now and I'll let you know as soon as I receive an update back.
IngaV
ok, thanks!:)
OCE_Michelle
Hi IngaV,
The fault has now been passed to BTOR for further investigation.
IngaV
Good morning. Any updates?
