on 08-04-2021 05:20 PM
I have a Talktalk wifi and I haven’t had problems connecting to the VPN in the past but recently I can’t seem to connect to VPN. When I try to connect using 4g I have no problem, it’s just when I try to connect on wifi it doesn’t work. After trying to connect on NordVPN it just says Error Timeout.
on 09-04-2021 01:22 PM
Hi Luq098
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 08-04-2021 08:52 PM
Hi @Luq098,
What make / model of router do you have, some of the older routers (particularly D-Link models) can be a bit temperamental with VPN access.
There are also a few tips here to help troubleshoot VPN issues. If the staff here thought the problem was due to your router they would be able to arrange a replacement.
Then they will hopefully be able to respond to this post within a working day or two.
@katysharp If you would like help from the staff here you would need to start your own topic, as they can only help one customer per topic. You would also need to complete your community profile as described above.
on 08-04-2021 08:48 PM
