Need my profile reset
ANSWERED
8 REPLIES 8
Paulm3
A few hours ago an Openreach engineer fixed a fault on my line.
He said that within one hour my profile would reset and take my speed from 1.4 back up to around 9.
This hasn't happened and there's no way to contact TalkTalk as understandably they have closed their centres
PLs can anyone help?
Gondola
Solution
Hi Paulm3
If the fault has been fixed and you're on a non-fibre connection then the Strategic Dynamic Line Management (SDLM) will be monitoring the line and will make a change overnight.  This change is usually between 2am and 3am.
Gondola - Volunteer 2017-2021
Paulm3
Lovely thanks for your help.
Need it for work.
Gondola
Hi Paulm3
You're welcome.
Just keep the router powered and connected 24/7 and recheck in the morning to make sure SDLM has moved the speed upwards.  The speed might change in steps rather than in one go.  Let us know if nothing has changed and we'll ask TalkTalk to check the line.
Paulm3
Ok thank you, I'm not holding my breath 😀
Gondola
...Yes, carry on breathing normally.  Monitor the blood pressure and if the blood boils then post back and we'll triage.
Paulm3
Morning,it has not improved, on 2.1 mbps
Gondola
Hi Paulm3
The line should have had a disconnect around 5 or so hours ago if SDLM has started to recover the line performance.
Carry out just the one power off of the router and switch on again after a minute.
Then check the sync speed.  Then leave the router powered and connected.
I've requested the TalkTalk team to take a look at the line performance and if deemed necessary to start a line reoptimisation sequence.
If the router isn't connected to the Master Socket then just a heads up that they may request you try that and possibly connect via a microfilter to the hidden Test Socket (if there is one) to rule out any issue with the Master Socket faceplate.
Your guide to master sockets
OCE_Karl
Hi Paulm3
I've optimised DLM for you.
