New router does not connect to broadband
Areid
Message 3 of 3
My existing router DSL 2740R is working well. I have been delivered a replacement model DSL3782 which does not connect to broadband. I am informed I will not be able to continue with my old router. Can you help me connect?
Chris-TalkTalk
Message 1 of 3
Hi Areid,
If you still need assistance can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @Areid,
You have probably been sent this router because TalkTalk are planning to give you a free upgrade from ADSL to Fibre, your existing router only supports ADSL and will not work on a Fibre connection, the DSL3782 will work on both ADSL and Fibre (VDSL).
What lights do you get on the DSL3782 when you try to use it.
Can you ensure you have used the new cables and microfilter (if required) that were supplied with the new router.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
