Nintendo Switch wont connect to internet - doesn't find network
karen446
Message 8 of 8
I have tried adding the internet manually with the SSID but it wont connect. I've turned everything off and on again multiple times and tried splitting 2.4 and 5 with different names. I have tried changing DNS manually in the switch settings. Don't know what else to do at this point!
7 REPLIES 7
Message 1 of 8
Hi Karen
Debbie 🙂
Message 2 of 8
Yes that would be great thanks
Message 3 of 8
Hi Karen
Ok, I can send a different router for testing, would you like me to arrange this?
Message 4 of 8
Hi I tried that but it didn't work. I'm not sure whether my switch usually connects using 2 or 5, I just know it wont find or connect to either.
Message 5 of 8
Hi Karen
If you factory reset your router using the pin hole reset for ten seconds and then don't split the SSID's does the device still not detect the wireless?
Do you usually have to connect the Nintendo switch using 2ghz or 5ghz?
Message 6 of 8
Added. And I am using sagemcom cs50001
Message 7 of 8
Hi Karen
Which router are you using? (make and model)
Please can you also add your TalkTalk landline number to your Community Profile.
