No Internet on 1 device
sraybone
Message 12 of 12
WiFi connections works on other devices, but one just 1 particular device (my phone), it shows "no internet" and will not connect. I have restarted and reset the router. There does not appear the option to reset the DNS settings on the router I have.
11 REPLIES 11
Message 1 of 12
Hi sraybone
Let us know how the connection compares with this router
sraybone
Message 2 of 12
Just to update that in the short time since my last post, the phones are now showing the "No Internet" message again when connected to the WiFi.
sraybone
Message 3 of 12
@Michelle-TalkTalk We don't have a second router, no. If you could send one for testing that would be fine & I can return the other.
Message 4 of 12
Thanks for trying this and I'm sorry to hear this. I still can't connect to the router. Do you have an alternative router that you can test with? If not then we can send a replacement router for testing purposes and a router returns bag so that one of the routers can be returned.
sraybone
Message 5 of 12
@Michelle-TalkTalk I have done the factory reset. The phones* now don't show the "No Internet" warning, but every website gives a "DNS_PROBE_FINISHED_BAD_CONFIG" / "IP address could not be found" error.
*(A friend's phone shows same behaviour as mine).
Message 6 of 12
Ok thanks for confirming. Could you try factory resetting the router and then letting us know once this has been completed please.
Restore your router to factory settings
sraybone
Message 7 of 12
Hi @Debbie-TalkTalk. I'm using the TalkTalk supplied router. It appears to be a Huawei, device version: DG8041W-2.T5.
Message 8 of 12
Hi sraybone
Apologies for this.
I'm unable to connect to your router, which router are you using? (make and model)
sraybone
Message 9 of 12
Thanks @martswain. I followed this advice but the problem still persists, @Debbie-TalkTalk.
Message 10 of 12
Hi sraybone
Have you tried the advice in martswain post?
martswain
Message 11 of 12
"Forget" the network on your phone, restart it and then try again.
