We moved home at the end of July. We were told new wifi would go live on the 13th of August. On the go live date, the internet and wireless lights showed green but the broadband light didn't turn on.
I called talktalk 3 times and spoke to advisors over web chat twice. They just keep asking me the same questions about if it is set up properly etc. Eventually, after filing a complaint, they agreed to send us a new router. New router arrived - same story.
I've seen people with similar issues online saying that it may be due to username/password certification issue or that the broadband line from the old flat has not been changed to the new flat with the exchange.
Can anyone please help?
Hi Rachel,
I'm sorry to hear you're experiencing problems with your service
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
Thanks you.
Our systems are showing that your router is currently connected to the internet. Could you tell me which lights are currently on on your router and the colour
The only lights showing are internet and wireless. Both of these are green. All other lights are off. We were sent a new router which shows the exact same.
Everything is plugged in correctly.
Are you sure the other lights are off. If the internet light is green the power and broandband/adsl lights should also be on?
I'm 100% sure the broadband light is not on and that everything is connected correctly; I've spoken to several people from TalkTalk already.
When we try to connect on our devices, an error message comes up saying broadband cable is not connected but it definitely is.
Seems to be the same issue as this: https://community.talktalk.co.uk/t5/Broadband/Internet-Not-Working-After-Home-Move-Despite-Router-Be...
I'm thinking the broadband line from our old flat has not been changed to the new flat with the exchange.
Could you switch your router off and leave it off for a minute or so and then switch back on and let me know when you've done this, and let me know if the lights are still the same
Yes, I have tried this several times and nothing works. Have also received a new router and done the same. It's obviously not the issue.
I asked you to restart the router so that I can see if the disconnection shows at my end on our systems, so could you do this please and let me know when you've done it
I'm not at home at the moment so I can't do that. However, I have tried this before when speaking with talktalk representatives and they have advised the connection is fine on their end.
I don't mean to sound frustrated but I'm having the same conversations again and again.
Sorry, I know it must be frustrating but I wasn't asking you to reboot the router to see if it would resolve the problem, just thinking that if you reboot the router and the disconnection shows at our end then it will indicate that you're on the correct circuit (or not, if it doesn't show)
When you're home could you try this and let us know at what time you rebooted the router
Can you also try dialing 17070 from your TalkTalk landline, this should read back your number to you so you can confirm that it's correct or not
Thanks for trying that, the reboot isn't showing on our systems, did you try 17070?
I haven't been able to unfortunately, as I don't have a house phone. Would the reboot not registering on your system indicate that our broadband isn't connected to the circuit?
Yes it should show on our systems, it would just have been handy to receive confirmation via 17070 and it would also show the circuit that you are connected to. I'll log this over to our network team for further investigation. Can you bump the thread tomorrow and we'll check for updates
Hi Rachel,
Could you just confirm that the router that you currently have connected is the one that we supplied
I'll try and borrow a phone from someone to try that. Yeah it's the router supplied by talktalk.
Thanks!
OK thanks. If the phone number read back to your isn't yours can you send me a PM with the number
