No internet connection
keff77
Message 21 of 21
I've been with TalkTalk for years and not had many issues. This week I have found that some of my hardware cannot connect to the internet, while other devices can. My smart plug, PS5 and Nvidia Shield cannot connect but phones, computers and Amazon devices are working without issue.
I assume there has been a firmware update to the router, but not sure how to get round the issue.
20 REPLIES 20
Message 1 of 21
@Debbie-TalkTalk ,
@Robbie8 has previously started his own topics here: Never reply to me. I hate this Company - TalkTalk Help & Support and here: How *@#][!![]'#[@#]!* is this company? - TalkTalk Help & Support
On each occasion a member of staff has offered to help but he has not replied or updated his profile to allow you to help.
Message 2 of 21
@Robbie8 - Please can you create your own topic on the Community, we can then look into this for you.
Robbie8
Message 3 of 21
Ring me ASAP because I’m stopping all further payments to you.
Robbie8
Message 4 of 21
TalkTalk is a SCAM company. DO NOT subscribe to them. I lose internet connection at least 3 times a week. Keep complaining but to no avail. To leave my contract they will charge me an extortionate amount of money.
Message 5 of 21
Hi keff77
I'm so glad to hear this.
Thanks for letting us know.
Debbie 🙂
Message 6 of 21
Hi Debbie,
I have received the new router and this has resolved the issues. Everything is now working as expected.
Many thanks for the support.
Message 7 of 21
Hi keff77
Message 8 of 21
Hi Debbie,
I'm more than happy to test a new router to see if that resolves the issue. Mine is several years old now, so it is possible that there is a hardware issue. Really appreciate all the assistance with this.
Many thanks
Message 9 of 21
Hi keff77
Would you like me to send a replacement router for testing?
Message 10 of 21
Yes I have completed pin hole resets three times now, but it doesn't have any effect. The same devices are still unable to connect to the internet.
Message 11 of 21
Hi keff77
Did you also complete a factory reset? (pin hole reset)
Skynet_TX
Message 12 of 21
You mentioned you had rebooted, but can you confirm you have tried a factory reset (by holding in the reset switch on the back for over 10 seconds). Note that this will lose any settings you have ever changed in the router.
Message 13 of 21
My devices that are working are connected to a mixture of 2.4 and 5 and have moved between them okay. There is no interference using a WiFi analyser. One device that's working is in the same place as one that isn't, and devices further away are fine.
When the PlayStation trys to connect it says Unable to obtain IP address in time
Skynet_TX
Message 14 of 21
Do you know if the devices are trying to connect to the 2.4GHz or 5GHz Wi-Fi bands, i.e. is one or the other of the bands having issues and the other is ok.
If you have one of the newer TalkTalk Wi-Fi Hubs then logging into the router will show you the details of which band the devices that are connecting ok are using. What make of router do you have ?
It could be caused by Wi-Fi interference, for example one of your neighbours could have set up a router that is broadcasting on the same channels as yours.
You could try changing the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
Message 15 of 21
I only have wireless devices. Some are connecting without issue, but others are having problems. These devices are closer to the router than others that do work, and nothing has changed from when everything was fine
Skynet_TX
Message 16 of 21
Is the problem affecting both wired and wireless devices (if you have both)
Message 17 of 21
I have tried a router reboot and I am still getting the same issue. I have a connection on some devices and not on others.
Message 18 of 21
Hi keff77
I've checked and the firmware hasn't been updated. Have you tried factory resetting the router using the pin hole reset for ten seconds?
Message 19 of 21
Hi Debbie,
My profile still had a previous phone number. I have now updated this to my current one.
Message 20 of 21
Hi keff77
Can I just check, have you added the correct landline number to your Community Profile? (Please do not post the number on this thread)
