No wireless internet
Pgriff22
Message 3 of 3
I’m having problems getting internet connection wirelessly. I think my devices at connecting to the router but won’t connect to the internet. I have a tv which is connected with a Ethernet cable and works fine but when I disconnect it and go wirelessly it won’t connect to the internet. I have mobiles, iPads, fire sticks that won’t work
ive tried to chat with Talktalk tech services twice but end up losing connection with them so no help there
Message 1 of 3
Hi Pgriff22
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Skynet_TX
Message 2 of 3
Hi @Pgriff22,
Presumably you have tried switching the router off and on again just to see if that resolves the issue ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
