Not Getting My Guaranteed Speed
bernjokas
Message 9 of 9
I'm not getting guaranteed speed. For the past week I'm only getting approx.  30 Mbps, my guaranteed speed is at 43 Mbps.
Tried running the live connection test but keep getting this error: ''Oops, it looks like there's been a technical issue :-(''
Any help would be appreciated.
8 REPLIES 8
Message 1 of 9
Hi bernjokas
Can I just check, has your router been at the test socket since your last post? (without being rebooted)
Message 2 of 9
OK, thanks for that. Please wait for further advice from the support team.
Message 3 of 9
Just did that now, still getting the same speeds.
Message 4 of 9
OK, the thing is that any issues on the voice side can affect the broadband connection. Have you tried connecting your router at the test socket with a microfilter?
Message 5 of 9
Yeah I know that but I dont have a landline phone, never needed one. Thanks anyways
Message 6 of 9
You have a phoneline even if you don't use it to make calls. Can you get your hands on a phone just to test?
bernjokas
Message 7 of 9
Hi, I dont have a home phone, it's only broadband.
Message 8 of 9
The speed is lower than it should be, and the profile has been lowered. Can you check the home phone and see if you have a clear dial tone with no noise or crackles on the line.
All usual tests are passing here.
