PS4 won't connect to talktalk
32 REPLIES 32
waqas722
Hello, I'm a new customer, joined talktalk on 2nd July but internet was having lots of issues, Engineer came down today morning and fixed a fault with the cabinet wiring. Now that internet is up and running, I am unable to connect my Playsation4 to talktalk. It gives error. However when I connect it to my mobile hotspot, it works perfectly. Also, I was a virginmedia customer and never had trouble connecting PS4.
Can anyone help with this?
waqas722
I've tried resetting router, using LAN only, nothing works!
What model router so you have ?
Also, when you say you have reset this, have you performed a full factory / pin reset.
Any issues with internet from other devices.
waqas722
Router says TalkTalk Wi-Fi Hub
Device Ver: FAST 5364-X.XX
Sagemcom
I have performed a reset using pin at the back of router.
waqas722
Internet is also stable since the engineer's visit.
waqas722
Hi @OCE_Karl ,
Is that sufficient information for you to check the problem?
Hi waqas722,
I'm sorry for the delay, thanks for the additional information. Are you trying to connect wired or wireless? What error message do you receive?
waqas722
Hi @OCE_Michelle  ,
I have tried with ethernet cable as well, it does not connect to the internet. It gave some error related to NAT.
And when I tried with the WiFi, it does not connect as well.
Hi waqas722
Do you have a different router that you can test with?
waqas722
Hi @OCE_Debbie ,
No, I only have the talktalk router that came via post and the engineer installed it.
Hi waqas722
I can send a replacement router for testing, would you like me to arrange this?
waqas722
Hi @OCE_Debbie ,
Sure, please. Will it be same as my current one?
Hi waqas722
I will send the same make and model of router, will this be ok?
waqas722
Hi @OCE_Debbie ,
Yes, please. I hope it will resolve this issue I'm having.
Hi waqas722
waqas722
Hi @OCE_Debbie  ,
Thank you. I will let you know when I receive and test the new router.
waqas722
Hi @OCE_Debbie
I haven't received the new router yet.I was waiting for it past few days. Could you please check if it had been sent?
Waqas
Hi waqas722
I've checked and there appears to be an issue with this router order, apologies for this.
I have asked our warehouse team to escalate this and you should receive this router within the next 48hrs.
waqas722
Hi @OCE_Debbie
It's been 48 hours, still haven't received any router yet.
