Persistent broadband issues
yemisipeters
Message 6 of 6
I have been having persistent issues with my Broadband and whenever I call customer service to report the issue, I get sent a message that all is working well. I am on Fibre 65 but the highest speed I have ever gotten on the speed test is about 20mp. Sometimes the broadband just doesn't work and this is really frustrating.
5 REPLIES 5
Message 1 of 6
Ok thank you and please let us know how the speed compares 🙂
yemisipeters
Message 2 of 6
Hi Michelle, I have only run the speed test on wireless.
I will turn the router off for 30 minutes as you have advised later today and let you know if the speed gets any better.
Message 3 of 6
Thank you! I have updated my profile and someone from the talktalk support team is now on the thread.
Message 4 of 6
Hi yemisipeters,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the sync speed looks good. Could you try powering down the router for a full 30 minutes please and then run another speed test as this will reset the current session and can often increase the throughput speed. Are you also running the speed tests wired or wireless?
Skynet_TX
Message 5 of 6
Hi @yemisipeters,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
Do the light(s) on your router indicate that it is losing connection to the internet and having to reconnect, as if you get lots of disconnections this can have a knock on effect on your speeds.
If you are having disconnections it would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
