Poor router speeds making my IPTV hopeless
Polentone71
Message 27 of 27
26 REPLIES 26
Message 1 of 27
Glad you got a resolution for the problem.
Polentone71
Message 2 of 27
Just got back from a week's holiday. Router was ready to be set up. Problem solved. So it was the router all along. Thanks to all for their input and help.
Message 3 of 27
Hi Polentone71
Polentone71
Message 4 of 27
Okay Debbie. Fingers crossed a new router does the trick. Thank you.
Message 5 of 27
Hi Polentone71
I've ordered you a different router for testing, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with the replacement router.
Gliwmaeden2
Message 6 of 27
@Polentone71, I explained in post #10 that staff work business hours, sometimes starting very early in the morning.
Karl is a member of Talktalk staff - he offered help 3 times on Tuesday
I am sure that you will find that he will follow this up for you.
Skynet_TX
Message 7 of 27
Don't create a new thread, that will just cause confusion, this thread is already in the staffs workflow, best to just wait for them to reply (hopefully tomorrow).
Message 8 of 27
okay thanks. Would I be best to open a new thread "FAO Talk Talk employee" or will they find this thread?
Skynet_TX
Message 9 of 27
Yes, the staff on this community only work normal office hours, so hopefully they will get back to you tomorrow and may be able to arrange a replacement router for you to try.
Polentone71
Message 10 of 27
So what happens now? I still have the problem. Are there any actual Talk Talk employees where that will see to it my service is restored to being fit for purpose?
Polentone71
Message 11 of 27
I don't have any other routers. I guess talk talk would have to send me one because this is obviously not a satisfactory situation.
Message 12 of 27
There are a number of wifi channels in use around you so this could be a wifi congestion issue.  You could try a different model router to see if it performs any better.
Polentone71
Message 13 of 27
Tried that. Still the same I'm afraid.
Message 14 of 27
Have a look at the below article from our help section :
https://community.talktalk.co.uk/t5/Articles/Change-your-wireless-channel/ta-p/2204684
Polentone71
Message 15 of 27
No, not yet. How would I go about doing that?
Message 16 of 27
Have you tried changing the wifi channels ?
Polentone71
Message 17 of 27
I managed to fix it safety pin in the wee reset hole on the back of the router. Still need to fix the WiFi latency problem though 🤔
Gliwmaeden2
Message 18 of 27
@Polentone71, staff will be back on here during the day. I'll alert them that you need help.
CSs are volunteers, so it's very much simply as and when we have time that you'll get support from fellow customers.
Staff reply during business hours Monday-Friday.
Polentone71
Message 19 of 27
In the absence of any help I went into my router settings to see if I could fix it myself. Bad mistake. I've managed to disable my router and can't enable it again. Guess I'll have to chat with an agent next time I have some free time. What a carry on.
Polentone71
Message 20 of 27
I finally found time to jump on my PC and it's easier to get around the site than on my mobile phone.
Problem could be this?
"Your Wi-Fi latency has been high for this device
This means we cannot guarantee online gaming or making calls over the internet over Wi-Fi on this device.
Reduce your Wi-Fi usage on this device. If this problem persists, please ....... on live chat."
That I believe might be my android iptv box that is being referred to.
