Port forwarding on Super Router
ANSWERED
ishalyminov
Hi! I can't get port forwarding to work on my D-Link Super Router.
I made this simple setup: my Raspberry Pi (reserved local IP 192.168.1.2) runs a simple server on port 8000. It responds perfectly from anywhere inside the local network by calling http://192.168.1.2:8000
My port forwarding rule for it is as on the screenshot.
With this config, I get "connection refused" every time I call http://{router's IP}:8000. Portchecker.co says that the port is open, yet forwarding doesn't work as expected.
I tried to make it UDP or Both TCP/UDP, switching between PVC1 and PVC2, setting different internal and external ports, disabling firewall, enabling DMZ for 192.168.1.2 - nothing makes it work.
Solution
You will get this if you try to make the connection from a device locally connected to your router to the internet and back in to the router's WAN IP address or a DDNS domain. This is because this is classed as loopback traffic & is blocked by all TalkTalk router's as they consider this a security risk.
Disconnect a phone from the WiFi & then try via 3/4G.
ishalyminov
Thanks a lot, now I get it!:)
