on 17-02-2019 01:38 AM
Tring to set up wifi to my play station and it says your Internet service provider or your router might be preventing the play station from connecting to the Internet
on 18-02-2019 09:07 AM
Hi Jameskelly
Which router are you using? (make and model)
Are you connected wired or wireless?
on 17-02-2019 10:39 AM
Are you getting that message after following the following instructions?
https://community.talktalk.co.uk/t5/Articles/Connect-your-Playstation-4/ta-p/2204901
I am only a TalkTalk customer.
